[gdal-dev] Motion: adopt RFC 64: Triangle, Polyhedral surface and TIN
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Fri Dec 9 05:12:28 PST 2016
Even Rouault-2 wrote
> Hi,
> There have been some good remarks, one regarding integration with GEOS
> that I've
> taken into account in the implementation, another one regarding the
> possibility to
> get indexed TIN that I think can be later added if needed.
> So I move to adopt RFC 64: Triangle, Polyhedral surface and TIN
>     https://trac.osgeo.org/gdal/wiki/rfc64_triangle_polyhedralsurface_tin
> Starting with my +1,
+1
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Motion-adopt-RFC-64-Triangle-Polyhedral-surface-and-TIN-tp5299355p5299369.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
