[gdal-dev] GDAL 2.1.2 compilation error
Even Rouault even.rouault at spatialys.com
Sun Dec 11 14:29:55 PST 2016
>  I worked around the problem by making a float-type-only copy of the
> templated function VRTComplexSource::RasterIOInternal() and calling that
> instead inside "vrtfilters.cpp" and GCC 4.6.3 seems to be happy with that.
I've reproduced the issue with another compiler and fixed it with
https://trac.osgeo.org/gdal/ticket/6748
http://www.spatialys.com
