[gdal-dev] Convert precipitation accumulations from HDF5 to GeoTiff
Rutger kassies at gmail.com
Tue Dec 13 05:17:18 PST 2016
Hey,
Based on the metadata from the file you posted i would guess the
x-coordinate of the right edge (lrx) should be about ~700km or ~700000m.
The column offset is 0, and there are 700 columns in the file which are
slightly over 1km. How would you end up with 800?
You can calculate the other corner coordinates in a similar fashion.
Regards,
Rutger
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Convert-precipitation-accumulations-from-HDF5-to-GeoTiff-tp5299661p5299678.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
