[gdal-dev] Convert precipitation accumulations from HDF5 to GeoTiff
Paul Meems bontepaarden at gmail.com
Tue Dec 13 06:33:33 PST 2016
Thanks again Rutger for your observation.
The bounding box was sent to me and I was already very happy the tiff is
located in The Netherlands ;)
I did a closer look at the meta data and with your explanation I come up
with this 'formula':
The ul is 0.0, -1 * geographic_geo_row_offset
lr is geographic_geo_number_columns, -1 * (geographic_geo_number_rows +
geographic_geo_row_offset)
Resulting in 0.0 3650 700, -4415
Thanks,
Paul
> 2016-12-13 14:17 GMT+01:00 Rutger <kassies at gmail.com>:
>> Hey,
>> Based on the metadata from the file you posted i would guess the
>> x-coordinate of the right edge (lrx) should be about ~700km or ~700000m.
>> The column offset is 0, and there are 700 columns in the file which are
>> slightly over 1km. How would you end up with 800?
>> You can calculate the other corner coordinates in a similar fashion.
>> Regards,
>> Rutger
>> View this message in context: http://osgeo-org.1560.x6.nabbl
>> e.com/gdal-dev-Convert-precipitation-accumulations-from-
>> HDF5-to-GeoTiff-tp5299661p5299678.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161213/2463d359/attachment.html>
