[gdal-dev] Question on 0th IFD offset when producing a JPEG-Compressed GeoTIFF (GDAL 1.11 vs 2.x)
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Fri Dec 16 05:29:10 PST 2016
On Fri, Dec 16, 2016 at 1:52 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> > Wondering if when generating overviews we still have a problem similar to
> > the one you have fixed in 2.0 or some data-updating issue.
> > These are my hypothesis on what is going on.
> > A simple translate with no overviews makes the file ending at 0x7555 with
> > offset of next IFD saying 0x0000.
> > When you add overviews, it writes a new IFD at 0x7556 with TAG entries,
> > then it encodes something and then it writes a new IFD.
> > At the end, it goes back updating the offset of the 1st overview IFD
> > (0xBBF0) making the one at 0x7556 being not referred anymore.
> > Does it make sense?
> With JPEG compression right ?
Right,
Indeed, before sending my previous email I have also tried with:
*gdaladdo -r average --config COMPRESS_OVERVIEW DEFLATE --config
PHOTOMETRIC_OVERVIEW RGB*
to understand if it was related to JPEG only but, even with these options,
the output overviews were jpeg compressed (I assume there is some kind of
coherency check in gdaladdo).
> I do reproduce something similar to your findings in 2.1 indeed. This no
> longer happens in trunk due to related improvements (
> https://trac.osgeo.org/gdal/wiki/CloudOptimizedGeoTIFF), I made in the
> last couple of weeks (using the same trick of creating a in-memory TIFF
> file to get the JPEG tables and set them direcly on the overview IFD at
> creation time).
Do you think this will be available in other series or does it introduce
new API/major changes which makes it available on 2.2.x only?
Thanks again for your precious feedbacks.
Cheers,
Daniele
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161216/099ea9b8/attachment.html>
