[gdal-dev] WMTS - Need TileLevel option Servers responding with bad capabilities
Even Rouault even.rouault at spatialys.com
Fri Dec 16 12:45:04 PST 2016
On vendredi 16 décembre 2016 13:14:37 CET esacree wrote:
> Even,
> I tried the daily build from 9-Dec-2016.  The new ZoomLevel parameter is
> there and the value is extracted.  Unfortunately, GDAL is still using the
> maximum tile level from the capabilities document.
That works fine for me. Could you share your .xml ?
Eve
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161216/f2a06d42/attachment.html>
