[gdal-dev] WMTS - Need TileLevel option Servers responding with bad capabilities
Even Rouault even.rouault at spatialys.com
Mon Dec 19 09:57:37 PST 2016
> I've tried both the "TileLevel" and the "ZoomLevel" parameters both
> separately and together.  The URL still shows the maximum tile zoom
level on
> the request.
You are probably not using a trunk build or a recent enough trunk build.
Your XML works fine for me and results in level 14 being fetched.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161219/e5b2fc88/attachment.html>
