[gdal-dev] export to WKT oddity
Even Rouault even.rouault at spatialys.com
Tue Feb 2 02:23:11 PST 2016
Le mardi 02 février 2016 10:42:07, Ari Jolma a écrit :
> Even
> Why the forcing to ISO variant in MultiCurve etc. exportToWkt method?
To avoid continuing generating legacy WKT with new geometry types.
 * For backward compatibility purposes, it exports the Old-style 99-402
 * extended dimension (Z) WKB types for types Point, LineString, Polygon,
 * MultiPoint, MultiLineString, MultiPolygon and GeometryCollection.
 * For other geometry types, it is equivalent to OGR_G_ExportToIsoWkt().
> That leads currently to outputs like
> GEOMETRYCOLLECTION (POINT EMPTY,MULTISURFACE Z EMPTY,POINT EMPTY)
Ah indeed, there might be some corner cases like the above one where this does
not work very well.
In the above, OGR_G_ExportToIsoWkt() should be rather used.
We could perhaps fix exportToWkt() in that situation to switch completely to
IsoWkt() as soon as there's a non-legacy geometry type in the collection ?
> which seems illogical to me.
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
