[gdal-dev] support for Czech Exchange Format for Land Consolidation
Even Rouault even.rouault at spatialys.com
Wed Feb 3 14:57:15 PST 2016
Le mercredi 03 février 2016 23:56:04, Martin Landa a écrit :
> Hi,
> 2016-02-03 23:31 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> > If it can be handled by the GML driver except for the geometries, you
> > could
> can GFS handle such data
> <uca id="0" jm="a" pr="b" />
> <GMLFeatureClassList>
>   <GMLFeatureClass>
>     <Name>ucastnici</Name>
>     <ElementPath>ucastnici</ElementPath>
>     <SRSName>urn:ogc:def:crs:EPSG::5514</SRSName>
>     <PropertyDefn>
>       <Name>id</Name>
>       <ElementPath>uca|id</ElementPath>
>       <Type>Integer64</Type>
>     </PropertyDefn>
>   </GMLFeatureClas>
> </GMLFeatureClassList>
> The above GFS files should handle:
> <uca>
>   <id>0</id>
> </uca>
> But not XML notation shown above, right? Thanks, Martin
Have a look at the "Getting XML attributes as OGR fields" section of
http://gdal.org/drv_gml.html
http://www.spatialys.com
