[gdal-dev] PDF and EXTRA_STREAM
Brent Fraser bfraser at geoanalytic.com
Thu Feb 4 19:22:55 PST 2016
I've been experimenting with generating Geospatial PDFs with GDAL and
would like to wrtie some extra text and lines to the PDF file. The PDF
drive has a Create Option of EXTRA_STREAM which looks pretty good.  I
can add text, lines and rectangles by doing:
   -co EXTRA_STREAM="BT 0 0 255 rg /FTimesRoman 50 Tf 1 0 0 1 1 1 Tm 100
200 Td (Hello World!) Tj ET 80 260 m 80 50 l h S 0.9 0.5 0.0 rg 400 50
300 200 re f"
But I think the length of the stream could get very long.  Any interest
in adding another Create Option like
EXTRA_STREAM_FILE=my_stuff.txt
so I could put all the extra in a separate file?
Best Regards,
Brent Fraser
