[gdal-dev] RFC 61: Call for vote on adoption
Tamas Szekeres szekerest at gmail.com
Fri Feb 5 01:34:11 PST 2016
+1
I'll update the mssql spatial driver accordingly.
Best regards,
Tamas
2016-02-05 9:04 GMT+01:00 Ari Jolma <ari.jolma at gmail.com>:
> I'd like to ask the PSC and others to vote on adopting RFC 61:  Support
> for measured geometries.
> The draft RFC is at
> https://trac.osgeo.org/gdal/wiki/rfc61_support_for_measured_geometries
> and a draft implementation is at
> https://github.com/ajolma/GDAL-XYZM
> which is tested at
> https://travis-ci.org/ajolma/GDAL-XYZM
> (the test #34, which passed, was the so far last one after core changes
> with unchanged autotests and a rather comprehensive set of WKT tests in the
> Perl tests directory)
> This is seemingly a small change but it is at the heart of OGR so it has
> some important implications. The only backwards incompatibilities that have
> appeared so far are with some drivers, for example shapefile, which can be
> lessened with, e.g., open options.
> Best,
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160205/52bfbaa3/attachment-0001.html>
