[gdal-dev] RFC 61: Call for vote on adoption
Sean Gillies sean at mapbox.com
Sat Feb 6 08:00:45 PST 2016
Hi Ari,
On Fri, Feb 5, 2016 at 1:04 AM, Ari Jolma <ari.jolma at gmail.com> wrote:
> I'd like to ask the PSC and others to vote on adopting RFC 61:  Support
> for measured geometries.
> The draft RFC is at
> https://trac.osgeo.org/gdal/wiki/rfc61_support_for_measured_geometries
> and a draft implementation is at
> https://github.com/ajolma/GDAL-XYZM
> which is tested at
> https://travis-ci.org/ajolma/GDAL-XYZM
> (the test #34, which passed, was the so far last one after core changes
> with unchanged autotests and a rather comprehensive set of WKT tests in the
> Perl tests directory)
> This is seemingly a small change but it is at the heart of OGR so it has
> some important implications. The only backwards incompatibilities that have
> appeared so far are with some drivers, for example shapefile, which can be
> lessened with, e.g., open options.
Can you explain more in detail about the backwards incompatibilities and
how to soften them? What's going to break and what are the specific options?
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160206/a04b5628/attachment.html>
