[gdal-dev] RFC 61: Call for vote on adoption
Even Rouault even.rouault at spatialys.com
Mon Feb 8 01:04:55 PST 2016
Le lundi 08 février 2016 08:17:28, vous avez écrit :
> 06.02.2016, 18:00, Sean Gillies kirjoitti:
> > Can you explain more in detail about the backwards incompatibilities
> > and how to soften them? What's going to break and what are the
> > specific options?
> Hi Sean,
> In the C++ and C API there are no backwards incompatibilities but the
> get/setCoordinateDimension() methods become deprecated since XYM and XYZ
> have the same dimension.  Is3D(), IsMeasured(), set3D(), and
> setMeasured() should be used instead.
> I don't know about the other drivers but Shapefile driver currently
> reads XYM geometries as XYZ and that will be changed so that XYM are
> read as XYM. I think that is the only incompatibility. A new open option
> MEASURE_AS_Z=YES/NO (or something) can be defined for backwards
> compatibility.
I don't think there's a strong need for such an option without confirmation
from users. The XYM support as XYZ was really a hack (people had no way to
know if the XYZ was XYM or XYZ, unless they read the .shp/.shx themselves).
And it is not clear how that would work in update scenarios (currently the M/Z
is discarded on update :  https://trac.osgeo.org/gdal/ticket/6331 )
Pirmin: as I see from https://trac.osgeo.org/gdal/ticket/2374 you were the one
to contribute the patch, what is your opinion on this ?
> Similar option can be defined for other drivers if they
> have the same feature.
I believe all other drivers currently discard the M values
http://www.spatialys.com
