[gdal-dev] RFC 61: Call for vote on adoption
Ari Jolma ari.jolma at gmail.com
Tue Feb 9 07:07:19 PST 2016
I declare this motion passed with +1 from Even, Tamas, Jukka and Daniel
and no -1.
I'll commit soon the changes to the core and then later the drivers:
memory, shape and pg. The goal is to keep the travis test build passing.
Ari
05.02.2016, 10:04, Ari Jolma kirjoitti:
> I'd like to ask the PSC and others to vote on adopting RFC 61: Support
> for measured geometries.
> The draft RFC is at
> https://trac.osgeo.org/gdal/wiki/rfc61_support_for_measured_geometries
> and a draft implementation is at
> https://github.com/ajolma/GDAL-XYZM
> which is tested at
> https://travis-ci.org/ajolma/GDAL-XYZM
> (the test #34, which passed, was the so far last one after core
> changes with unchanged autotests and a rather comprehensive set of WKT
> tests in the Perl tests directory)
> This is seemingly a small change but it is at the heart of OGR so it
> has some important implications. The only backwards incompatibilities
> that have appeared so far are with some drivers, for example
> shapefile, which can be lessened with, e.g., open options.
> Best,
> Ari
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160209/4a556682/attachment.html>
