[gdal-dev] RFC 61: Call for vote on adoption
Kurt Schwehr schwehr at gmail.com
Wed Feb 10 05:21:02 PST 2016
I'm +0.  Neither for nor against.
One request:
#define OGR_G_NOT_EMPTY_POINT 0x1
#define OGR_G_3D 0x2
#define OGR_G_MEASURED 0x4
#define OGR_G_IGNORE_MEASURED 0x8
Can you make these a static const int or static const unsigned int member
of the OGRGeometry class?  #defines make life more difficult.
find . -name \*.h -o -name \*.cpp | xargs grep '#define' | egrep '[0-9"]' |
egrep -v '[(]|\[' | wc -l
    4517
A random example of doing this:
https://trac.osgeo.org/gdal/browser/trunk/gdal/alg/gdal_simplesurf.h?rev=33127#L93
// Descriptor length
static const int DESC_SIZE = 64;
-kurt
On Wed, Feb 10, 2016 at 4:53 AM, Peter Halls <p.halls at york.ac.uk> wrote:
> > Types on page 2).
> > PointZ
> > A PointZ consists of a triplet of double-precision coordinates in the
> order
> > X, Y, Z plus a measure"
> > I had misinterpreted their meaning of "optional" here and submitted a
> > documentation query to ESRI on being told I was wrong.  The response was
> > that M being optional means that it can be valueless, but is always
> > present.
> Woo, really ???? That's a genuine scoop.
> I reported it to  Frank at the time ... but several email systems later, I
> no longer have my copies of the correspondence with ESRI nor the OGR bug
> report, in which these were copied.  Somewhere I may still have a backup of
> my work area, to see what I did in my code.  However, as you say, this is
> 20+ years ago ....  It was something which, at the time, was causing us
> some problems ....
> I think you to be correct in your Shapelib summary below:
> Unless I'm seriously mistaken, shapelib / OGR has produced XYZ shapefiles
> without M values for more than 20 years. I'm surprised we wouldn't have
> heard about that if such shapefiles couldn't be read. Or perhaps ESRI
> software is robust to missing M too
> Best wishes,
> Peter
> On 10 February 2016 at 12:31, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Le mercredi 10 février 2016 13:05:20, Peter Halls a écrit :
>> > Ari, et al,
>> >       ESRI handle this in a non-intuitive way:  XYM is supported, but Z
>> > always has a Measure, so is XYZM!   The formal definition is here:
>> > https://www.*esri*.com/library/whitepapers/pdfs/*shapefile*.pdf
>>  (1998)
>> >       Shape Types having Z are defined on pp19ff where it states:
>> > "Shape Types inX,Y,Z Space
>> > Shapes of this type have an optional coordinate
>> > M. Note that "no data" value can be specified as a value for M (see
>> Numeric
>> > Types on page 2).
>> > PointZ
>> order
>> > present.
>> heard
>> about that if such shapefiles couldn't be read. Or perhaps ESRI software
>> is
>> > Best wishes,
>> > Peter
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> Peter J Halls, PhD Student, Post-war Reconstruction and Development Unit
> (PRDU),
>                       University of York
> Snail mail: PRDU, Derwent College, University of York,
>                 Heslington, York YO10 5DD
> This message has the status of a private and personal communication
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160210/74a2e4b8/attachment.html>
