[gdal-dev] Ogrinfo, WKT and geometries with Z
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Thu Feb 11 01:53:06 PST 2016
Ogrinfo is printing the WKT of XYZ geometries this way:
ogrinfo polygonz.gpkg -al
INFO: Open of `polygonz.gpkg'
      using driver `GPKG' successful.
Layer name: polygonz
Geometry: Unknown (any)
Feature Count: 1
Extent: (340.000000, 420.000000) - (560.000000, 580.000000)
Layer SRS WKT:
(unknown)
FID Column = fid
Geometry Column = geom
OGRFeature(polygonz):1
  POLYGON ((340 580 1,560 580 2,560 420 3,340 580 1))
In "OpenGISĀ® Implementation Standard for Geographic information - Simple
feature access - Part 1: Common architecture" POINT is defined as 2
dimensional. Wouldn't the right WKT be
  POLYGON Z ((340 580 1,560 580 2,560 420 3,340 580 1)) ?
I have tested that some software like OpenJUMP and PostGIS do accept POLYGON
with 3 coordinates while some other like Spatialite do not. Because Ari is
now working with XYZ(M) code would this also be worth a review?
-Jukka Rahkonen-
