[gdal-dev] GDAL 2.0.2 doesn't compile with Kakadu 7.7.1
Andre Hollstein andre.hollstein at gfz-potsdam.de
Fri Feb 12 01:13:06 PST 2016
Dear Even,
thanks for pointing me to https://trac.osgeo.org/gdal/changeset/31517, I
will use this. Maybe it would help to avoid confusion to reflect the
need to set
CXXFLAGS="-DKDU_MAJOR_VERSION=7 -DKDU_MINOR_VERSION=7 in the ./configure
--help message. I was missing this info.
Thanks a lot again,
André
On 02/12/2016 10:03 AM, Even Rouault wrote:
> Andre,
>> The preferred way to include all the
>> Kakadu API's is to link against
>>   >both libkdu_v77R.o and libkdu_a77R.o, where the latter is built by the
>> "managed" makefiles.
>>   >Anyway, it may be that all you have to do is add
>> "avx2_region_deocmpressor.o" (and possibly
>>   >"avx2_region_compositor.o") to the GDAL build environment.
> Yes, the kakadu support would probably need to be revisited and linking to a
> single file would be better (although that its changing name, see the v77, is
> kind of annoying...)
> Anyway since GDAL 2.0, you need to pass explicitly the Kakadu version by
> defining CXXFLAGS like CXXFLAGS="-DKDU_MAJOR_VERSION=7 -DKDU_MINOR_VERSION=7"
> ./configure [other_options]
> But Kakadu v7.7 support is in trunk only : you likely need to apply
>> I checked the fmts/o directory and copied all *.o files from kakadu into
>> this directory. Then, called make again which ran without errors. When
>> using python, I was able to read a jpeg200 image with gdal. However,
>> this worked only with 2.0.2, using the version from github, the gdal
>> module was missing from python.
> Perhaps the GDAL Python bindings you use don't link to the GDAL library you
> built manually ? You may have to play with LD_LIBRARY_PATH to point to your
> GDAL libs.
>> So it seems there is a bug in the gdal build system when compiling with
>> kakadu 7.7.1
>> Kind Regards, André Hollstein
Dr. André Hollstein
Sektion 1.4 Fernerkundung
Tel.: +49 (0)331/288-28969
Fax: +49 (0)331/288-28969
E-Mail: andre.hollstein at gfz-potsdam.de
___________________________________
Helmholtz-Zentrum Potsdam
Deutsches GeoForschungsZentrum GFZ
Stiftung des öff. Rechts Land Brandenburg
Telegrafenberg, 14473 Potsdam
Haus 17, Raum 20.23
