[gdal-dev] Dropping Windows-CE support?
Kurt Schwehr schwehr at gmail.com
Sun Feb 14 13:24:19 PST 2016
Andrew,
You might find useful the changes listed in the ticket that I used for the
remove of macos <= 9 and wince:
https://trac.osgeo.org/gdal/ticket/6133
-kurt
On Sun, Feb 14, 2016 at 12:13 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 13 February 2016 at 21:30, byte <btx at rutrus.com> wrote:
> > 1.4 version has started wince support, so just have to try later
> versions one
> > by one until it compiles ? :-) or maybe someone know the _latest_ working
> > one ?
> AFAIR, Windows CE had been maintained across 1.4.x line only,
> or may be even 1.5.x.
> You may have a luck with later releases though.
> Best regards,
> Mateusz Łoskot, http://mateusz.loskot.net
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160214/08728777/attachment.html>
