[gdal-dev] Core dump using gdal_translate to create geopackage
Jesse McGraw jlmcgraw at gmail.com
Mon Feb 15 06:46:15 PST 2016
I was fiddling with Even's geopackage examples
<http://erouault.blogspot.com/2014/12/gdal-geopackage-raster-support.html>
when I came across a core dump issue in gdal_translate
gdal version is compiled from github trunk as of 15 February 2016 under
Ubuntu 15.10 x64
    gdal_translate --version
    GDAL 2.1.0dev, released 2015/99/99
I can share the geotiff in question if need be.  Let me know if I can
provide any other helpful information
Basic command is:
    gdal_translate \
         Washington_SEC.tif \
         test.gpkg \
         -of GPKG \
         -co TILE_FORMAT=PNG \
         -co TILING_SCHEME=GoogleMapsCompatible
Out from Valgrind is:
    jlmcgraw at UbuntuMate1504:~/Documents/myPrograms/gdal_tests$
    CPL_DEBUG=ON \
     > valgrind --tool=memcheck --leak-check=yes --read-var-info=yes \
     > gdal_translate \
     >     test.gpkg \
     >     -of GPKG \
    ==30978== Memcheck, a memory error detector
    ==30978== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward
    et al.
    ==30978== Using Valgrind-3.11.0 and LibVEX; rerun with -h for
    copyright info
    ==30978== Command: gdal_translate Washington_SEC.tif test.gpkg -of
    GPKG -co TILE_FORMAT=PNG -co TILING_SCHEME=GoogleMapsCompatible
    ==30978==
    GDAL: GDALOpen(Washington_SEC.tif, this=0xf7e9d80) succeeds as GTiff.
    Input file size is 15538, 11309
    GDAL: GDAL_CACHEMAX = 100 MB
    GDAL: GDALWarpKernel()::GWKGeneralCase()
    Src=0,0,1944x1415 Dst=0,0,2737x1992
    0GDAL: GDALWarpKernel()::GWKGeneralCase()
    Src=1941,0,1945x1415 Dst=2737,0,2737x1992
    .GDAL: GDALWarpKernel()::GWKGeneralCase()
    Src=3883,0,1945x1415 Dst=5474,0,2737x1992
    --30978-- warning: evaluate_Dwarf3_Expr: unhandled DW_OP_ 0xf2
    ==30978== Invalid write of size 8
    ==30978==    at 0x4C3259F: memset (in
    /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
    ==30978==    by 0x5692CD8: memset (string3.h:90)
    ==30978==    by 0x5692CD8: GDALGeoPackageDataset::ReadTile(int, int,
    unsigned char*, bool*) (gdalgeopackagerasterband.cpp:641)
    ==30978==    by 0x5692FA2: GDALGeoPackageDataset::ReadTile(int, int)
    (gdalgeopackagerasterband.cpp:489)
    ==30978==    by 0x5694B51: GDALGeoPackageRasterBand::IReadBlock(int,
    int, void*) (gdalgeopackagerasterband.cpp:733)
    ==30978==    by 0x5553B15: GDALRasterBand::GetLockedBlockRef(int,
    int, int) (gdalrasterband.cpp:1142)
    ==30978==    by 0x5572525: GDALRasterBand::IRasterIO(GDALRWFlag,
    int, int, int, int, void*, int, int, GDALDataType, long long, long
    long, GDALRasterIOExtraArg*) (rasterio.cpp:307)
    ==30978==    by 0x557312A:
    GDALDataset::BlockBasedRasterIO(GDALRWFlag, int, int, int, int,
    void*, int, int, GDALDataType, int, int*, long long, long long, long
    long, GDALRasterIOExtraArg*) (rasterio.cpp:2938)
    ==30978==    by 0x551B09C: GDALDataset::RasterIO(GDALRWFlag, int,
    int, int, int, void*, int, int, GDALDataType, int, int*, long long,
    long long, long long, GDALRasterIOExtraArg*) (gdaldataset.cpp:1991)
    ==30978==    by 0x551B11D: GDALDatasetRasterIO (gdaldataset.cpp:2034)
    ==30978==    by 0x56384C4: GDALWarpOperation::WarpRegion(int, int,
    int, int, int, int, int, int, int, int, double, double)
    (gdalwarpoperation.cpp:1370)
    ==30978==    by 0x56387C6: GDALWarpOperation::ChunkAndWarpImage(int,
    int, int, int) (gdalwarpoperation.cpp:720)
    ==30978==    by 0x57A9F5A: GDALGeoPackageDataset::CreateCopy(char
    const*, GDALDataset*, int, char**, int (*)(double, char const*,
    void*), void*) (ogrgeopackagedatasource.cpp:3242)
    ==30978==  Address 0x0 is not stack'd, malloc'd or (recently) free'd
    ==30978==
    ==30978==
    ==30978== Process terminating with default action of signal 11 (SIGSEGV)
    ==30978==  Access not within mapped region at address 0x0
    ==30978==  If you believe this happened as a result of a stack
    ==30978==  overflow in your program's main thread (unlikely but
    ==30978==  possible), you can try to increase the size of the
    ==30978==  main thread stack using the --main-stacksize= flag.
    ==30978==  The main thread stack size used in this run was 8388608.
    ==30978==
    ==30978== HEAP SUMMARY:
    ==30978==     in use at exit: 138,658,730 bytes in 10,473 blocks
    ==30978==   total heap usage: 58,500 allocs, 48,027 frees,
    326,332,504 bytes allocated
    ==30978==
    ==30978== 1,032 bytes in 1 blocks are possibly lost in loss record
    4,171 of 4,283
    ==30978==    at 0x4C2BBCF: malloc (in
    ==30978==    by 0x7CECC56: ??? (in
    /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6)
    ==30978==    by 0x7CC92F5: ??? (in
    ==30978==    by 0x7CCC5A6: ??? (in
    ==30978==    by 0x7CEB222: ??? (in
    ==30978==    by 0x7D200D7: ??? (in
    ==30978==    by 0x7D29826: sqlite3_step (in
    ==30978==    by 0x7D2A899: sqlite3_exec (in
    ==30978==    by 0x57B297B: SQLCommand(sqlite3*, char const*)
    (ogrgeopackageutility.cpp:41)
    ==30978==    by 0x57A4D5C:
    GDALGeoPackageDataset::FinalizeRasterRegistration()
    (ogrgeopackagedatasource.cpp:1383)
    ==30978==    by 0x57A9CBA: GDALGeoPackageDataset::CreateCopy(char
    void*), void*) (ogrgeopackagedatasource.cpp:3150)
    ==30978==    by 0x5522F48: GDALDriver::CreateCopy(char const*,
    GDALDataset*, int, char**, int (*)(double, char const*, void*),
    void*) (gdaldriver.cpp:803)
    ==30978==
    4,172 of 4,283
    ==30978==    by 0x5695415:
    GDALGeoPackageDataset::WriteShiftedTile(int, int, int, int, int,
    int, int) (gdalgeopackagerasterband.cpp:1645)
    ==30978==    by 0x5695CAC:
    GDALGeoPackageRasterBand::IWriteBlock(int, int, void*)
    (gdalgeopackagerasterband.cpp:2121)
    ==30978==    by 0x555805F: GDALRasterBlock::Write()
    (gdalrasterblock.cpp:743)
    ==30978==
    ==30978== 1,304 bytes in 1 blocks are possibly lost in loss record
    4,186 of 4,283
    ==30978==    by 0x7CCD0FF: ??? (in
    ==30978==    by 0x7D003AE: ??? (in
    ==30978==    by 0x7D007FA: ??? (in
    ==30978==    by 0x7D012E8: ??? (in
    ==30978==    by 0x7D0374F: ??? (in
    ==30978==    by 0x7D06D63: ??? (in
    ==30978==    by 0x7D09554: ??? (in
    ==30978==    by 0x7D2346A: ??? (in
    ==30978==
    ==30978== 3,912 bytes in 3 blocks are possibly lost in loss record
    4,228 of 4,283
    ==30978==    by 0x7D06EB7: ??? (in
    ==30978==
    ==30978== 710,680 bytes in 545 blocks are possibly lost in loss
    record 4,275 of 4,283
    ==30978==    by 0x7D09228: ??? (in
    ==30978==
    ==30978== LEAK SUMMARY:
    ==30978==    definitely lost: 0 bytes in 0 blocks
    ==30978==    indirectly lost: 0 bytes in 0 blocks
    ==30978==      possibly lost: 717,960 bytes in 551 blocks
    ==30978==    still reachable: 137,940,770 bytes in 9,922 blocks
    ==30978==                       of which reachable via heuristic:
    ==30978==                         length64           : 483,616 bytes
    in 2,334 blocks
    ==30978==         suppressed: 0 bytes in 0 blocks
    ==30978== Reachable blocks (those to which a pointer was found) are
    not shown.
    ==30978== To see them, rerun with: --leak-check=full
    --show-leak-kinds=all
    ==30978==
    ==30978== For counts of detected and suppressed errors, rerun with: -v
    ==30978== ERROR SUMMARY: 6 errors from 6 contexts (suppressed: 0 from 0)
    Segmentation fault (core dumped)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160215/e56f22cb/attachment-0001.html>
