[gdal-dev] gdal not recognizing ellpsoid properly in esri grid format
Even Rouault even.rouault at spatialys.com
Mon Feb 15 10:37:13 PST 2016
Le lundi 15 février 2016 18:54:51, Dominik Schneider a écrit :
> Hi,
> I was sent an esri grid that uses a spherical ellpsoid with +a and +b
> parameters but this not being read properly. It is being assigned
> +ellps=WGS84 when read with raster::raster() in R 3.2.3 but also when using
> gdalinfo on the command line.  I'm using GDAL 1.11.3 from kyngchaos.com on
> OS X 10.11.3
> Not sure if this is a known issue or subsequently fixed in later versions
> so I wanted to report it here. I didn't see a ticket that addresses this in
> particular.
There was no support for reading custom ellipsoid from old-style .prj. I've
just added it in trunk.
http://www.spatialys.com
