[gdal-dev] [OSGeo-Standards] CSV spatial data on the web
Stefan Keller sfkeller at gmail.com
Tue Feb 16 10:57:43 PST 2016
Hi Jeremy
Thanks for the info.
I assume you are aware of GeoCSV and related software like the
well-known OGR (and the #TheShapefileChallenge ):
http://giswiki.hsr.ch/GeoCSV
:Stefan
2016-02-16 19:40 GMT+01:00 Jeremy Palmer <JPalmer at linz.govt.nz>:
> For forks that are interested W3C has setup a CSV on the Web Working Group https://www.w3.org/2013/csvw/wiki/Main_Page to provide recommendations for better interoperability when working with CSV datasets.
> I raised an issue a few months ago on the working documents, with my main issue being that spatial datatypes are not really accounted for:
> https://github.com/w3c/csvw/issues/795
> I believe this is an important thing to solve as publishing large open datasets is something that is not well addressed and keeps getting reinvented by multiple groups or vendors.
> They have now responded to my issue with this response:
> https://github.com/w3c/csvw/pull/822
> But I think this response needs a wider community view.
> Cheers,
> Jeremy
> This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
> Standards mailing list
> Standards at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/standards
