[gdal-dev] Compiling with ECW/JP2ECW support enabled
Jonathan Williams jonvwill at verizon.net
Wed Feb 17 07:38:30 PST 2016
I have tried this; I've added the Ubuntu-GIS repository, but none of the
builds are for 64 bit 14.04 LTS, from what I've seen.
I've also tried to force the issue with the instructions here:
http://gis.stackexchange.com/a/102088
However, the build fails, perhaps because I'm using version 5.2.1 of
ERDAS' SDK with libNCSEcw.so.5.2.1, or perhaps because I'm using Gdal
2.0.2? the compile messages indicate a couple of errors.
/usr/local/include/gdal_priv.h:226:19: error: ‘char**
GDALOpenInfo::papszSiblingFiles’ is private
     char        **papszSiblingFiles;
ecwdataset.cpp:2526:48: error: within this context
                                    poOpenInfo->papszSiblingFiles, NULL );
make: *** [ecwdataset.o] Error 1
...as well as...
ecwdataset.cpp:440:91: error: no matching function for call to
‘ECWRasterBand::SetDefaultHistogram(double&, double&, int&, int*&)’
Note that I did *not* attempt to install QGIS or libgdal-dev, as I was
concerned some of the other dependencies might regress work that I'd
done with compiling Jasper, etc.
Best,
Jonathan
On 2/17/2016 12:26 AM, Tomaka, Jacek wrote:
> HI Jonathan,
> Have you tried compiling in  ECW/JP2 support as a plugin?
> Regards.
> Jacek Tomaka
> -----Original Message-----
> From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jonathan Williams
> Sent: Wednesday, 17 February 2016 4:51 AM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Compiling with ECW/JP2ECW support enabled
> Hello,
> In addition to my previous question regarding OpenCL support bafflement, I've run into difficulty compiling GDAL 2.02 with ECW support.
> I've compiled with "--with-ecw=/usr/local/hexagon", as the 5.2 SDK is located there, and symlinked the /usr/local/hexagon/lib/(x64|x86)/release/libNCSEcw.so library to /usr/local/lib/libNCSEcw.so .
> Configuration completes with no errors, as does compilation. The ./configure output indicates that support is selected, and config.log says all libraries were found.
> However, the completed utilities do not list ecw as a readable format, and indeed, they cannot read ecw files (much less jpeg2000 ones).
> I understand there have been libgdal-ecw scripts that some have run to enable support; however, I haven't found one for this situation (Ubuntu desktop 14.04.3 LTS 64 bit, with gdal 2.02).
> Is it the case that these scripts also need to be run to enable ecw support? or am I foolishly missing something?
> I see in the config.log that -ECW_FLAGS are set to '-DHAVE_ECW_BUILDNUMBER_H -DLINUX -DX86 -DPOSIX -DHAVE_COMPRESS -DECW_COMPRESS_RW_SDK_VERSION', and thought perhaps a 32 bit library had been selected; however, manually modifying the flag "DX86" to "DX64"
> simply produced an error.
> Any insight would be appreciated.
> Best regards,
> Jonathan Williams
> gdal-dev mailing list
