[gdal-dev] GDAL 1.11.3 ISIS3 Driver
Jay L. jlaura at asu.edu
Fri Feb 19 12:49:55 PST 2016
Just built GDAL 1.11.3 using the following:
./configure --prefix=/home/travis/miniconda/envs/_build
--with-geos=/home/travis/miniconda/envs/_build/bin/geos-config
--with-static-proj4=/home/travis/miniconda/envs/_build
--with-hdf5=/home/travis/miniconda/envs/_build
--with-xerces=/home/travis/miniconda/envs/_build
--with-armadillo=/home/travis/miniconda/envs/_build
--with-netcdf=/home/travis/miniconda/envs/_build
--with-openjpeg=/home/travis/miniconda/envs/_build --with-gif=internal
--with-geotiff=internal --with-python --disable-rpath --without-pam
--with-pg=/home/travis/miniconda/envs/_build/bin/pg_config
The full build is available at:
https://travis-ci.org/USGS-Astrogeology/conda-gdal/builds/110469950
The ISIS3 driver is not building (the ISIS2 driver is).  Does the ISIS3
driver have some dependency?
Thanks,
Jay
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160219/1c3ec1d5/attachment.html>
