[gdal-dev] gml: array data type size
Even Rouault even.rouault at spatialys.com
Mon Jan 4 08:38:11 PST 2016
Le lundi 04 janvier 2016 16:47:47, Martin Landa a écrit :
> Hi Even,
> 2015-12-17 13:57 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> first of all thanks for the feedback.
> > The proper solution would be to have the GML driver consider each
> > <soi:DetailniTEA> as a separate layer/table and add cross feature links
> > between "top" features and "sub" features.
> Do you have any idea how much work it would be do modify GML driver in
> this way and where to start?
Actually you could check the ogr_gml_56 test case of ogr/ogr_gml_read.py that
handles something similar to what you have. It might be that you wouldn't need
to do change codes by providing the adequate .xsd / .gfs.
> Thanks, Martin
http://www.spatialys.com
