[gdal-dev] Is there Any limitation in name of the file name in CreateDataSource in Filegeodb
Gane R gane.prog at gmail.com
Tue Jan 5 11:17:34 PST 2016
It is weired, when I call CreateDataSource as I had discussed earlier, I
send a large filename with absoluted path to it. I causes a crash at when
called from java via jni
Is there any limitation in the name of the filename when passing to
CreateDataSource call.
poDrv->CreateDataSource <= example
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160106/df55d2ea/attachment.html>
