[gdal-dev] Changing pixel values of GDAL VRT
Even Rouault even.rouault at spatialys.com
Thu Jan 7 02:15:23 PST 2016
Le jeudi 07 janvier 2016 10:51:00, cl a écrit :
> When use the nearblack tool I get: ERROR 1: Writing through
> VRTSourcedRasterBand is not supported.
Yes that's what I implied with my previous answer. nearblack only works on
"plain" output datasets with full random read-write capabilities (typically
GTiff, HFA).
> http://osgeo-org.1560.x6.nabble.com/Changing-pixel-values-of-GDAL-VRT-tp52
> 41432p5244066.html Sent from the GDAL - Dev mailing list archive at
> Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
