[gdal-dev] PDF when converted to GeoTIFF maps to location offset
Gane R gane.prog at gmail.com
Sun Jan 10 21:17:40 PST 2016
Thanks for your timely response. I got the offset issue seem to work
fine with above quotes revision. Thank-you once again.
On 1/8/16, Gane R <gane.prog at gmail.com> wrote:
> On Fri, Jan 8, 2016 at 3:10 PM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Le vendredi 08 janvier 2016 10:33:06, Gane R a écrit :
>> > Thanks for the giving me the revision
>> > I saw it and it seems that I already have that part of code with me
>> > that
>> > non rotation cases
>> > I have gdal2.0.1 with all the PDF fixes (for I sent PDF and got fixed
>> > on
>> > trunk).
>> > I have the (above mentioned revision), is there any other fix done
>> > apart
>> > from the PDF I have sent to be seem that it work with trunk
>> Some fixes are in trunk only, not in the GDAL 2.0.X branch
>> > I got a copy of the trunk and tried to build a version and both the
>> version
>> > seem to look same by visual inspection.
>> > Can plz confirm that the above fix is the fix for this shift.
>> > Thanks
>> > Gane
>> > On Thu, Jan 7, 2016 at 7:17 PM, Even Rouault
>> > wrote:
>> > > Le jeudi 07 janvier 2016 14:33:29, Gane R a écrit :
>> > > > Can you please point to that revision on trunk so that I can verify
>> If
>> > > > I have the change with me.
>> > > I guess this must be this one :
>> > > https://trac.osgeo.org/gdal/changeset/31638/
>> > > But just update to the latest one to also get the yesterday fix.
>> > > > Thanks
>> > > > Gane
>> > > > On Thu, Jan 7, 2016 at 3:21 PM, Even Rouault
>> > > > wrote:
>> > > > > Le jeudi 07 janvier 2016 08:49:57, Gane R a écrit :
>> https://drive.google.com/file/d/0B4shTM1bPS5TWkVtWDNhMEZtNE0/view?usp=sha
>> > > > > ri
>> > > > > > ng
>> > > > > > Here is a link to another PDF with I experience offset shift.
>> > > > > > I have not yet tested with prev fix on truk, Will that fix
>> resolve
>> > > this
>> > > > > > also .. or this is something else causing it.
>> > > > > Eh, you should do your homework ;-)
>> > > > > Overlays nicely with a basemap with trunk. Nothing to do with
>> > > yesterday's
>> > > > > fix
>> > > > > but with one committed of a few weeks ago.
>> > > > > Spatialys - Geospatial professional services
>> > > > > http://www.spatialys.com
