[gdal-dev] Error compiling trunk (nitf)
Even Rouault even.rouault at spatialys.com
Thu Jan 14 11:05:47 PST 2016
Le jeudi 14 janvier 2016 19:54:32, Jeff McKenna a écrit :
> Hi all!
> With today's trunk, I'm getting a compile error, during linking, with
> Windows visual studio 2008:
> Creating library gdal_i.lib and object gdal_i.exp
> nitfwritejpeg_12.obj : error LNK2001: unresolved external symbol "void
> __cdecl jpeg_vsiio_
> dest_12(struct jpeg_compress_struct12 *,struct _iobuf *)"
> (?jpeg_vsiio_dest_12@@YAXPAUjpeg
> _compress_struct12@@PAU_iobuf@@@Z)
> The problem line seems to be in nitfwritejpeg_12.cpp on the 4th line:
> https://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/nitf/nitfwritejpeg_12.
> cpp#L4
> This line seems to have been added during a change a few weeks ago with
> the comment "Fix One Definition Rule violations"
> https://trac.osgeo.org/gdal/changeset/32062/#file8
> I'm not sure if this is relevant, but my builds use libjpeg-9a
> Please let me know if you have any ideas, thanks,
Jeff,
is this is a fresh checkout / clean build ?
Even
http://www.spatialys.com
