[gdal-dev] Intersection of two Layers
Kai Muehlbauer kai.muehlbauer at uni-bonn.de
Mon Jan 18 01:56:37 PST 2016
at the moment I calculate the intersection of two OGR Layers (A, B) by
iterating over features/geometries (GA) of layer A and then calling
GA.Intersection(GB) for every Feature/Geometry (GB) of B. I set a
spatial filter for layer B with every GA. The intersections
features/geometries are written to a result layer (C).
In my use case the features/geometries of layer B are much smaller than
the features of layer A. Means that quite a big number of B's geometries
are fully contained in A's geometries.
To speed things up, I check for containment GA.contains(GB). If GB is
contained in GA, I just copy GB to C, otherwise I calculate
GA.Intersection(GB) and write this to C.
I found that I also could use the layer intersection function
(OGRLayer::Intersection). Unfortunately the intersection is calculated
for every feature/geometry.
Would it be possible to extend the layer intersection function to allow
for containment check (eg. as an option) and just copy the contained
geometries without calculation of expensive intersection? Suggestions,
opinions?
In my use case I get improvements of around 20% of processing time.
Cheers,
Kai
