[gdal-dev] map info and projections from GeoTIFF file to create ENVI header
nguler at jlab.org nguler at jlab.org
Mon Jan 18 08:13:14 PST 2016
Dmitry and All,
I just downloaded the set of tiff files from earthexplorer and run gdalinfo on
it. Please see below. I am missing some fields in the output information. It
is different from what you got. I don't know what can cause this? My
gdalinfo.exe is not good? Any idea?
C:\Cubes\LC80080472013174LGN00.tar>gdalinfo LC80080472013174LGN00_B1.TIF
Driver: GTiff/GeoTIFF
Files: LC80080472013174LGN00_B1.TIF
       .\LC80080472013174LGN00_MTL.txt
Size is 7571, 7411
Coordinate System is:
PROJCS["unnamed",
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-69],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]]]
Origin = (145185.000000000000000,2189715.000000000000000)
Pixel Size = (30.000000000000000,-30.000000000000000)
Metadata:
  AREA_OR_POINT=Point
  METADATATYPE=ODL
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (  145185.000, 2189715.000)
Lower Left  (  145185.000, 1967385.000)
Upper Right (  372315.000, 2189715.000)
Lower Right (  372315.000, 1967385.000)
Center      (  258750.000, 2078550.000)
Band 1 Block=7571x1 Type=UInt16, ColorInterp=Gray
C:\Cubes\LC80080472013174LGN00.tar>gdalinfo --version
GDAL 2.0.1, released 2015/09/15
> I have the 2.0.1 version:
> C:\warmerda\bld\bin>gdalinfo --version
> I will check the history of the file I have. Maybe it is modified. I will also
> download the same file from earthexplorer and try my routines on it.
> Thanks for the suggestions. I appreciate.
> - Nevzat
> -----Original Message-----
> From: Dmitry Baryshnikov [mailto:bishop.dev at gmail.com]
> Sent: Sunday, January 17, 2016 12:57 PM
> To: Nevzat Guler <nguler at jlab.org>; gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] map info and projections from GeoTIFF file to create
> ENVI header
> I downloaded this scene from earthexplorer, and everything is fine:
> $ gdalinfo LC80080472013174LGN00_B1.TIF
>         ./LC80080472013174LGN00_MTL.txt
> Size is 7571, 7411
> PROJCS["WGS 84 / UTM zone 19N",
>      GEOGCS["WGS 84",
>          DATUM["WGS_1984",
>              SPHEROID["WGS 84",6378137,298.257223563,
>                  AUTHORITY["EPSG","7030"]],
>              AUTHORITY["EPSG","6326"]],
>          PRIMEM["Greenwich",0,
>              AUTHORITY["EPSG","8901"]],
>          UNIT["degree",0.0174532925199433,
>              AUTHORITY["EPSG","9122"]],
>          AUTHORITY["EPSG","4326"]],
>      UNIT["metre",1,
>          AUTHORITY["EPSG","9001"]],
>      AXIS["Easting",EAST],
>      AXIS["Northing",NORTH],
>      AUTHORITY["EPSG","32619"]]
> Metadata:
>    AREA_OR_POINT=Point
>    METADATATYPE=ODL
>    INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  145185.000, 2189715.000) ( 72d23' 7.97"W, 19d46'16.43"N) Lower
> Left  (  145185.000, 1967385.000) ( 72d20'44.51"W, 17d45'55.15"N) Upper Right
> (  372315.000, 2189715.000) ( 70d13' 8.50"W, 19d47'56.92"N) Lower Right (
> 372315.000, 1967385.000) ( 70d12'16.74"W, 17d47'24.74"N)
> Center      (  258750.000, 2078550.000) ( 71d17'19.50"W, 18d47' 4.68"N)
> $ gdalinfo --version
> GDAL 2.1.0dev, released 2015/99/99
> What is your gdal version? Maybe the Landsat geotiff was modified from some
> software?
> Best regards,
>      Dmitry
> 17.01.2016 20:15, Nevzat Guler пишет:
>> Thank you Dmitry,
>> What is the best way to extract the information we got using gdalinfo.exe by
>> using GDAL classes, within a C++ code? As I mentioned, I am using
>> GetGeoTransform and GetProjectionRef() but the results miss many of the
>> information (specifically the map info elements as I explained in the
>> previous email).
>> On another note, I actually get a different output from gdalinfo.exe using
>> my file (please see the printed result below). I got the geotiff file from
>> my colleague. When I open the file with ENVI, I get all the information,
>> including GEOGCS information.
>> Can it be that my file is just corrupted and that's why I don't get all the
>> information from GetGeoTransform and GetProjectionRef()? But then how would
>> ENVI is able to extract this information if it were not in the file?
>> Thanks again, - Nevzat
>> C:\Cubes\Landsat\LC80080472013174LGN00>gdalinfo
>>         .\LC80080472013174LGN00_MTL.txt Size is 7571, 7411 Coordinate
>> System is:
>> PROJCS["unnamed",
>>      UNIT["metre",1,
>> Metadata:
>>    AREA_OR_POINT=Point
>>    METADATATYPE=ODL
>>    INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left  (  145185.000, 2189715.000) Lower Left  (  145185.000,
>> 1967385.000) Upper Right (  372315.000, 2189715.000) Lower Right (
>> From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of
>> Dmitry Baryshnikov
>> Sent: Sunday, January 17, 2016 6:57 AM
>> To: gdal-dev at lists.osgeo.org
>> create ENVI header
>> Hi Nevzat,
>> The landsat geotiff already have CRS embeded in file
>> $ gdalinfo LC80150362013097LGN03_B1.TIF
>> Files: LC80150362013097LGN03_B1.TIF
>>          ./LC80150362013097LGN03_MTL.txt Size is 7281, 7261 Coordinate
>> System is:
>> PROJCS["WGS 84 / UTM zone 17N",
>>       GEOGCS["WGS 84",
>>           DATUM["WGS_1984",
>>       PARAMETER["central_meridian",-81],
>>       UNIT["metre",1,
>>       AUTHORITY["EPSG","32617"]]
>> Origin = (706185.000000000000000,3943515.000000000000000)
>> Metadata:
>>     AREA_OR_POINT=Point
>>     METADATATYPE=ODL
>>     INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left  (  706185.000, 3943515.000) ( 78d43'24.74"W, 35d36'50.15"N)
>> Lower Left  (  706185.000, 3725685.000) ( 78d46'35.65"W, 33d39' 3.82"N)
>> Upper Right (  924615.000, 3943515.000) ( 76d19' 2.05"W, 35d32'39.74"N)
>> Lower Right (  924615.000, 3725685.000) ( 76d25'33.46"W, 33d35'10.99"N)
>> Center      (  815400.000, 3834600.000) ( 77d33'38.95"W, 34d36'17.35"N)
>> Band 1 Block=7281x1 Type=UInt16, ColorInterp=Gray
>> And this is right CRS.
>> Where do you get you geotiff?
>> Best regards,
>>       Dmitry
>> 17.01.2016 03:41, Nevzat Guler пишет:
>>> Dear experts,
>>> I am reading LANDSAT GeoTIFF files and combining bands to create and
>>> ENVI cube.
>>> I am using GDAL to read the GeoTIFF file, and my own custom cube
>>> writer to write the ENVI style cube. Transferring the map information
>>> proved to be a bit convoluted. I seek your help to figure out this.
>>> My first problem is to access map info from GeoTIFF file. The map
>>> info
>>> includes:
>>> map info = {UTM, 1.000, 1.000, 145185.000, 2189715.000,
>>> 3.0000000000e+001, 3.0000000000e+001, 19, North, WGS-84,
>>> units=Meters}
>>> I am able to get the location (x,y), and pixel size (x,y) from :
>>> double adfGeoTransform[6];
>>> srcDS->GetGeoTransform(adfGeoTransform);
>>> But, I could not find any way to get the other variables in the
>>> string: UTM, pixel tie points, Unit and DATUM. Is there any way to get
>>> them?
>>> Finally, for the Coordinate System String, GDAL gives me:
>>> PROJCS["unnamed",PROJECTION["Transverse_Mercator"],PARAMETER["latitud
>>> e
>>> _of_or
>>> igin
>>> ",0],PARAMETER["central_meridian",-69],PARAMETER["scale_factor",0.999
>>> 6
>>> ],PARA
>>> METE
>>> R["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",
>>> 1
>>> But I should actually get
>>> PROJCS["UTM_Zone_19N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0
>>> 0,0],A
>>> UTHO
>>> RITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],U
>>> N
>>> IT["de
>>> gree
>>> ",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"
>>> ]],PRO
>>> JECT
>>> ION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETE
>>> R
>>> ["cent
>>> ral_
>>> meridian",-69],PARAMETER["scale_factor",0.9996],PARAMETER["false_east
>>> i
>>> ng",50
>>> 0000
>>> ],PARAMETER["false_northing",0],UNIT["Meter",1]]
>>> GDAL gives me PROJCS, "unnamed". And no GEOGCS information is given.
>>> I am able to get the coordinate system properties by using the
>>> following commands but I first need to set few things to use exportToWTK.
>>>>>         OGRSpatialReference oSRS;
>>>>>         char *pszWKT = NULL;
>>>>>         oSRS.SetProjCS("UTM_Zone_19N");
>>>>>         oSRS.SetWellKnownGeogCS("WGS84");
>>>>>         oSRS.SetUTM(19, TRUE);
>>>>>         oSRS.exportToWkt(&pszWKT);
>>>>>         printf("%s\n", pszWKT);
>>> However, this requires me to set SetProjCS, SetWellKnownGeogCS and
>>> SetUTM first. I don't know these before I read the file. Is there any
>>> way to get them from the file so that I don't need prior knowledge to
>>> create the header. When I pull the GeoTIFF file into ENVI, all these
>>> information is already there. If this list is only or development
>>> purposes, please let me know if there is any other email list that
>>> can give me guidance on this quest.
>>> I appreciate your help and suggestions.
>>> Best regards,
>>> - Nevzat
>>> gdal-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Nevzat Guler
Senior Scientist
Spectral Sciences
Phone: 781-273-4770
http://www.spectral.com/index.shtml
http://www.linkedin.com/in/nevzatguler
