[gdal-dev] map info and projections from GeoTIFF file to create ENVI header
nguler at jlab.org nguler at jlab.org
Mon Jan 18 08:53:54 PST 2016
Yes, Thank you Even, I was missing the GDAL_DATA environmental variable. Now I
get the same gdalinfo output. Do I need to set this variable while using the
C++ classes you suggested before: GetGeoTransform and GetProjectionRef()..?
Because, there also I had the same problem.
Best regards, - Nevzat
> Le lundi 18 janvier 2016 17:13:14, nguler at jlab.org a écrit :
>> Dmitry and All,
>> I just downloaded the set of tiff files from earthexplorer and run gdalinfo
>> on it. Please see below. I am missing some fields in the output
>> information. It is different from what you got. I don't know what can
>> cause this? My gdalinfo.exe is not good? Any idea?
> Have a look at the FAQ entries about GDAL_DATA :
> https://trac.osgeo.org/gdal/wiki/FAQInstallationAndBuilding#WhatisGDAL_DATAenvironmentvariable
>> C:\Cubes\LC80080472013174LGN00.tar>gdalinfo LC80080472013174LGN00_B1.TIF
>> Driver: GTiff/GeoTIFF
>> Files: LC80080472013174LGN00_B1.TIF
>>        .\LC80080472013174LGN00_MTL.txt
>> Size is 7571, 7411
>> Coordinate System is:
>> PROJCS["unnamed",
>>     PROJECTION["Transverse_Mercator"],
>>     PARAMETER["latitude_of_origin",0],
>>     PARAMETER["central_meridian",-69],
>>     PARAMETER["scale_factor",0.9996],
>>     PARAMETER["false_easting",500000],
>>     PARAMETER["false_northing",0],
>>     UNIT["metre",1,
>>         AUTHORITY["EPSG","9001"]]]
>> Origin = (145185.000000000000000,2189715.000000000000000)
>> Pixel Size = (30.000000000000000,-30.000000000000000)
>> Metadata:
>>   AREA_OR_POINT=Point
>>   METADATATYPE=ODL
>> Image Structure Metadata:
>>   INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left  (  145185.000, 2189715.000)
>> Lower Left  (  145185.000, 1967385.000)
>> Upper Right (  372315.000, 2189715.000)
>> Lower Right (  372315.000, 1967385.000)
>> Center      (  258750.000, 2078550.000)
>> Band 1 Block=7571x1 Type=UInt16, ColorInterp=Gray
>> C:\Cubes\LC80080472013174LGN00.tar>gdalinfo --version
>> GDAL 2.0.1, released 2015/09/15
>> > I have the 2.0.1 version:
>> > C:\warmerda\bld\bin>gdalinfo --version
>> > I will check the history of the file I have. Maybe it is modified. I will
>> > also download the same file from earthexplorer and try my routines on
>> > it. Thanks for the suggestions. I appreciate.
>> > - Nevzat
>> > -----Original Message-----
>> > From: Dmitry Baryshnikov [mailto:bishop.dev at gmail.com]
>> > Sent: Sunday, January 17, 2016 12:57 PM
>> > To: Nevzat Guler <nguler at jlab.org>; gdal-dev at lists.osgeo.org
>> > Subject: Re: [gdal-dev] map info and projections from GeoTIFF file to
>> > create ENVI header
>> > I downloaded this scene from earthexplorer, and everything is fine:
>> > $ gdalinfo LC80080472013174LGN00_B1.TIF
>> >         ./LC80080472013174LGN00_MTL.txt
>> > Size is 7571, 7411
>> > PROJCS["WGS 84 / UTM zone 19N",
>> >      GEOGCS["WGS 84",
>> >          DATUM["WGS_1984",
>> >              SPHEROID["WGS 84",6378137,298.257223563,
>> >                  AUTHORITY["EPSG","7030"]],
>> >              AUTHORITY["EPSG","6326"]],
>> >          PRIMEM["Greenwich",0,
>> >              AUTHORITY["EPSG","8901"]],
>> >          UNIT["degree",0.0174532925199433,
>> >              AUTHORITY["EPSG","9122"]],
>> >          AUTHORITY["EPSG","4326"]],
>> >      UNIT["metre",1,
>> >          AUTHORITY["EPSG","9001"]],
>> >      AXIS["Easting",EAST],
>> >      AXIS["Northing",NORTH],
>> >      AUTHORITY["EPSG","32619"]]
>> > Metadata:
>> >    AREA_OR_POINT=Point
>> >    METADATATYPE=ODL
>> >    INTERLEAVE=BAND
>> > Corner Coordinates:
>> > Upper Left  (  145185.000, 2189715.000) ( 72d23' 7.97"W, 19d46'16.43"N)
>> > Lower Left  (  145185.000, 1967385.000) ( 72d20'44.51"W, 17d45'55.15"N)
>> > Upper Right (  372315.000, 2189715.000) ( 70d13' 8.50"W, 19d47'56.92"N)
>> > Lower Right ( 372315.000, 1967385.000) ( 70d12'16.74"W, 17d47'24.74"N)
>> > Center      (  258750.000, 2078550.000) ( 71d17'19.50"W, 18d47' 4.68"N)
>> > $ gdalinfo --version
>> > GDAL 2.1.0dev, released 2015/99/99
>> > What is your gdal version? Maybe the Landsat geotiff was modified from
>> > some software?
>> > Best regards,
>> >      Dmitry
>> > 17.01.2016 20:15, Nevzat Guler пишет:
>> >> Thank you Dmitry,
>> >> What is the best way to extract the information we got using
>> >> gdalinfo.exe by using GDAL classes, within a C++ code? As I mentioned,
>> >> I am using GetGeoTransform and GetProjectionRef() but the results miss
>> >> many of the information (specifically the map info elements as I
>> >> explained in the previous email).
>> >> On another note, I actually get a different output from gdalinfo.exe
>> >> using my file (please see the printed result below). I got the geotiff
>> >> file from my colleague. When I open the file with ENVI, I get all the
>> >> information, including GEOGCS information.
>> >> Can it be that my file is just corrupted and that's why I don't get all
>> >> the information from GetGeoTransform and GetProjectionRef()? But then
>> >> how would ENVI is able to extract this information if it were not in
>> >> the file?
>> >> Thanks again, - Nevzat
>> >> C:\Cubes\Landsat\LC80080472013174LGN00>gdalinfo
>> >>         .\LC80080472013174LGN00_MTL.txt Size is 7571, 7411 Coordinate
>> >> System is:
>> >> PROJCS["unnamed",
>> >>      UNIT["metre",1,
>> >> Metadata:
>> >>    AREA_OR_POINT=Point
>> >>    METADATATYPE=ODL
>> >>    INTERLEAVE=BAND
>> >> Corner Coordinates:
>> >> Upper Left  (  145185.000, 2189715.000) Lower Left  (  145185.000,
>> >> 1967385.000) Upper Right (  372315.000, 2189715.000) Lower Right (
>> >> From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of
>> >> Dmitry Baryshnikov
>> >> Sent: Sunday, January 17, 2016 6:57 AM
>> >> To: gdal-dev at lists.osgeo.org
>> >> create ENVI header
>> >> Hi Nevzat,
>> >> The landsat geotiff already have CRS embeded in file
>> >> $ gdalinfo LC80150362013097LGN03_B1.TIF
>> >> Files: LC80150362013097LGN03_B1.TIF
>> >>          ./LC80150362013097LGN03_MTL.txt Size is 7281, 7261 Coordinate
>> >> System is:
>> >> PROJCS["WGS 84 / UTM zone 17N",
>> >>       GEOGCS["WGS 84",
>> >>           DATUM["WGS_1984",
>> >>       PARAMETER["central_meridian",-81],
>> >>       UNIT["metre",1,
>> >>       AUTHORITY["EPSG","32617"]]
>> >> Origin = (706185.000000000000000,3943515.000000000000000)
>> >> Metadata:
>> >>     AREA_OR_POINT=Point
>> >>     METADATATYPE=ODL
>> >>     INTERLEAVE=BAND
>> >> Corner Coordinates:
>> >> Upper Left  (  706185.000, 3943515.000) ( 78d43'24.74"W, 35d36'50.15"N)
>> >> Lower Left  (  706185.000, 3725685.000) ( 78d46'35.65"W, 33d39' 3.82"N)
>> >> Upper Right (  924615.000, 3943515.000) ( 76d19' 2.05"W, 35d32'39.74"N)
>> >> Lower Right (  924615.000, 3725685.000) ( 76d25'33.46"W, 33d35'10.99"N)
>> >> Center      (  815400.000, 3834600.000) ( 77d33'38.95"W, 34d36'17.35"N)
>> >> Band 1 Block=7281x1 Type=UInt16, ColorInterp=Gray
>> >> And this is right CRS.
>> >> Where do you get you geotiff?
>> >> Best regards,
>> >>       Dmitry
>> >> 17.01.2016 03:41, Nevzat Guler пишет:
>> >>> Dear experts,
>> >>> I am reading LANDSAT GeoTIFF files and combining bands to create and
>> >>> ENVI cube.
>> >>> I am using GDAL to read the GeoTIFF file, and my own custom cube
>> >>> writer to write the ENVI style cube. Transferring the map information
>> >>> proved to be a bit convoluted. I seek your help to figure out this.
>> >>> My first problem is to access map info from GeoTIFF file. The map
>> >>> info
>> >>> includes:
>> >>> map info = {UTM, 1.000, 1.000, 145185.000, 2189715.000,
>> >>> 3.0000000000e+001, 3.0000000000e+001, 19, North, WGS-84,
>> >>> units=Meters}
>> >>> I am able to get the location (x,y), and pixel size (x,y) from :
>> >>> double adfGeoTransform[6];
>> >>> srcDS->GetGeoTransform(adfGeoTransform);
>> >>> But, I could not find any way to get the other variables in the
>> >>> string: UTM, pixel tie points, Unit and DATUM. Is there any way to get
>> >>> them?
>> >>> Finally, for the Coordinate System String, GDAL gives me:
>> >>> PROJCS["unnamed",PROJECTION["Transverse_Mercator"],PARAMETER["latitud
>> >>> e
>> >>> _of_or
>> >>> igin
>> >>> ",0],PARAMETER["central_meridian",-69],PARAMETER["scale_factor",0.999
>> >>> 6
>> >>> ],PARA
>> >>> METE
>> >>> R["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",
>> >>> 1
>> >>> But I should actually get
>> >>> PROJCS["UTM_Zone_19N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>> >>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0
>> >>> 0,0],A
>> >>> UTHO
>> >>> RITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],U
>> >>> N
>> >>> IT["de
>> >>> gree
>> >>> ",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4326"
>> >>> ]],PRO
>> >>> JECT
>> >>> ION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETE
>> >>> R
>> >>> ["cent
>> >>> ral_
>> >>> meridian",-69],PARAMETER["scale_factor",0.9996],PARAMETER["false_east
>> >>> i
>> >>> ng",50
>> >>> 0000
>> >>> ],PARAMETER["false_northing",0],UNIT["Meter",1]]
>> >>> GDAL gives me PROJCS, "unnamed". And no GEOGCS information is given.
>> >>> I am able to get the coordinate system properties by using the
>> >>> following commands but I first need to set few things to use
>> >>> exportToWTK.
>> >>>>>         OGRSpatialReference oSRS;
>> >>>>>         char *pszWKT = NULL;
>> >>>>>         oSRS.SetProjCS("UTM_Zone_19N");
>> >>>>>         oSRS.SetWellKnownGeogCS("WGS84");
>> >>>>>         oSRS.SetUTM(19, TRUE);
>> >>>>>         oSRS.exportToWkt(&pszWKT);
>> >>>>>         printf("%s\n", pszWKT);
>> >>> However, this requires me to set SetProjCS, SetWellKnownGeogCS and
>> >>> SetUTM first. I don't know these before I read the file. Is there any
>> >>> way to get them from the file so that I don't need prior knowledge to
>> >>> create the header. When I pull the GeoTIFF file into ENVI, all these
>> >>> information is already there. If this list is only or development
>> >>> purposes, please let me know if there is any other email list that
>> >>> can give me guidance on this quest.
>> >>> I appreciate your help and suggestions.
>> >>> Best regards,
>> >>> - Nevzat
>> >>> _______________________________________________
>> >>> gdal-dev mailing list
>> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Nevzat Guler
>> Senior Scientist
>> Spectral Sciences
>> Phone: 781-273-4770
>> http://www.spectral.com/index.shtml
>> http://www.linkedin.com/in/nevzatguler
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Nevzat Guler
Senior Scientist
Spectral Sciences
Phone: 781-273-4770
