[gdal-dev] Ubuntu multiple gdal installations, each with its python bindings
Even Rouault even.rouault at spatialys.com
Sun Jan 24 04:38:27 PST 2016
Le samedi 23 janvier 2016 08:40:06, bojan.surma at gmail.com a écrit :
> Hello,
> I’m using a Ubuntu server with PostGIS on GDAL 1.10 with python bindings.
> Now, I’m trying to add a 2.0.1 with python bindings so I could do some
> tests. I need to do this without changing the existing environment.
I've updated instructions for non-root install on :
https://trac.osgeo.org/gdal/wiki/BuildingOnUnix
(but lightly tested them so there might be some errors/missing steps)
> What’s the best way to do this?
> Thank you
http://www.spatialys.com
