[gdal-dev] Ubuntu multiple gdal installations, each with its python bindings
Didier Richard Didier.Richard at ign.fr
Sun Jan 24 09:12:11 PST 2016
Another solution would be to use containers (docker) by installing all the relevant softwares (using a postgres container as basis for instance). It is more work than compiling as Even suggests, but is by far less intrusive to the host system.
didier
________________________________________
De : gdal-dev [gdal-dev-bounces at lists.osgeo.org] de la part de Even Rouault [even.rouault at spatialys.com]
Date d'envoi : dimanche 24 janvier 2016 13:38
À : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] Ubuntu multiple gdal installations,      each with its python bindings
Le samedi 23 janvier 2016 08:40:06, bojan.surma at gmail.com a écrit :
> Hello,
> I’m using a Ubuntu server with PostGIS on GDAL 1.10 with python bindings.
> Now, I’m trying to add a 2.0.1 with python bindings so I could do some
> tests. I need to do this without changing the existing environment.
I've updated instructions for non-root install on :
https://trac.osgeo.org/gdal/wiki/BuildingOnUnix
(but lightly tested them so there might be some errors/missing steps)
> What’s the best way to do this?
> Thank you
http://www.spatialys.com
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
