[gdal-dev] GDAL/OGR 2.0.2 RC2 Available for Review
Even Rouault even.rouault at spatialys.com
Sun Jan 24 13:29:32 PST 2016
Hi Sandro,
Thanks for the report. I've just added ${CFLAGS}. See
https://trac.osgeo.org/gdal/ticket/6330
I've pushed the fix in the branch but will not re-issue a RC just for that
reason as the problem has likely existed forever. You could also use
--with-freexl=/path/to/install/prefix as a likely workaround, or add
-I/usr/local/include in CC itself.
Regards,
Even
> Hi Even,
> I casually noticed that the ./configure script fails to correctly
> identify libfreexl on Windows when using the MinGW/MSYS compiler.
> this error message is always returned even when the most recent
> version of libfreexl is correctly installed:
> "freexl too old. Needs freexl >= 1.0"
> the cause is rather easy to be identified into configure.in:
> line 3432: if test -z "`${CC} testfreexl.c -c 2>&1`" ; then
> differently from Linux, MinGW/MSYS doesn't automatically searches
> the header files into /usr/local/include, so explicitly setting
> this way CFLAGS (or CPPFLAGS, CXXFLAGS) is usually required.
> the following patch fixes the MinGW/MSYS issue and seems to be
> harmless on Linux:
> - if test -z "`${CC} testfreexl.c -c 2>&1`" ; then
> + if test -z "`${CC} $CFLAGS $CPPFLAGS $CXXFLAGS testfreexl.c -c 2>&1`"
> ; then
> bye Sandro
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
