[gdal-dev] US Survey Ft being used for a projection in PDF
Gane R gane.prog at gmail.com
Wed Jan 27 09:00:37 PST 2016
Here is a link to PDF
https://drive.google.com/file/d/0B4shTM1bPS5TaVZ2OWxxR0MtM2s/view?usp=sharing
I remember I got the US Ft unit fix for PDF driver from trunk.
So will that fix will be sufficient to handle PDFs with "US Survey Ft being
used for a projection"
Thanks
Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160127/281ce19f/attachment.html>
