[gdal-dev] PDF Projection support
Gane R gane.prog at gmail.com
Thu Jan 28 06:51:54 PST 2016
Here is a link for the PDF
https://drive.google.com/file/d/0B4shTM1bPS5TaVZ2OWxxR0MtM2s/view?usp=sharing
and the gdalinfo is as follows, Does this projection is supported by the
PDF driver.
Driver: PDF/Geospatial PDF
Files:Plant_GIS_ANSI_D_View4_Treatment_50Scale.pdf
Size is 5100, 3300
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["unknown",
        DATUM["NAD_1983_2011",
            SPHEROID["GRS_1980",6378137,298.257222101],
            TOWGS84[-0.9738,1.9453,0.5486,0,0,0,0]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",24.33333333333333],
    PARAMETER["central_meridian",-82],
    PARAMETER["scale_factor",0.9999411764705882],
    PARAMETER["false_easting",200000],
    PARAMETER["false_northing",0],
    UNIT["Meter",1]]
GeoTransform =
  199522.582988026, 0.07895862924306769, 0.06393943724398152
  305449.4714977542, 0.06393943724398152, -0.07895862924306769
Metadata:
  CREATION_DATE=D:20160113122026-05'00'
  CREATOR=Esri ArcMap 10.3.0.4322
  NEATLINE=POLYGON ((200064.22163200931
305474.83433632617,199733.36708641629 305206.91360799421,199538.33690883874
305447.75581972388,199869.19145443285 305715.67654805584,200064.22163200931
305474.83433632617))
  PRODUCER=TerraGo Technologies Publisher for ArcGIS GeoPDF Export version:
6.8.2.100
Corner Coordinates:
Upper Left  (  199522.583,  305449.471) ( 82d 0'17.33"W, 27d 5'26.39"N)
Lower Left  (  199733.583,  305188.908) ( 82d 0' 9.67"W, 27d 5'17.93"N)
Upper Right (  199925.272,  305775.563) ( 82d 0' 2.71"W, 27d 5'36.99"N)
Lower Right (  200136.272,  305514.999) ( 81d59'55.05"W, 27d 5'28.52"N)
Center      (  199829.428,  305482.235) ( 82d 0' 6.19"W, 27d 5'27.46"N)
Band 1 Block=5100x1 Type=Byte, ColorInterp=Red
Band 2 Block=5100x1 Type=Byte, ColorInterp=Green
Band 3 Block=5100x1 Type=Byte, ColorInterp=Blue
Thanks
Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160128/02f0984c/attachment.html>
