[gdal-dev] Streaming Parser for OGR GeoJSON Driver
Even Rouault even.rouault at spatialys.com
Fri Jan 29 01:19:48 PST 2016
> Perhaps it works because I am only appending to a single layer that has the
> same schema throughout?
Yes
> I did test this, but the performance was indeed slower. Is there a way for
> me to specify the schema before-hand and avoid a full first pass?
> Perhaps for a driver implementation with a streaming parser, I could write
> a vrt before hand, then pipe in GeoJSON that matches that schema?
Yes, if you know the fields, you can do something like:
<OGRVRTDataSource>
  <OGRVRTUnionLayer>
    <OGRVRTLayer name="OGRGeoJSON">
        <SrcDataSource>tmp1.json</SrcDataSource>
    </OGRVRTLayer>
        <SrcDataSource>tmp2.json</SrcDataSource>
    </OGRVRTLayer>
    <Field name="..." type="..."/>
  </OGRVRTUnionLayer>
</OGRVRTDataSource>
And if you don't know them but are OK to take the one of the first sources (so
your current strategy) :
<OGRVRTDataSource>
  <OGRVRTUnionLayer>
    </OGRVRTLayer>
    </OGRVRTLayer>
    <FieldStrategy>FirstLayer</FieldStrategy>
  </OGRVRTUnionLayer>
</OGRVRTDataSource>
http://www.spatialys.com
