[gdal-dev] make install fails
Marco Atzeri marco.atzeri at gmail.com
Fri Jul 1 04:35:14 PDT 2016
On 01/07/2016 13:20, Kai Muehlbauer wrote:
> Hi Matthias,
> I did experience the same issue. See
> https://lists.osgeo.org/pipermail/gdal-dev/2016-July/044678.html
> Although I did not find the root cause of this, I found that in my use
> case, copying and unsetting CC and CXX environment variables did the trick.
> So what I did is:
> export CF_CC=$CC
> export CF_CXX=$CXX
> unset CC CXX
> ./configure CC=$CF_CC \
>             CXX=$CF_CXX \
>             --prefix=$PREFIX
> make
> Hoping for more insight by gdal-devs.
> Cheers,
> Kai
same workaround "unset CC CXX"
is implemented for cygwin package build.
   https://lists.osgeo.org/pipermail/gdal-dev/2016-April/044171.html
and it looks this bug is present by long long time
   http://www.michael-joost.de/gdal_install.html
Regards
Marco
