[gdal-dev] Amplitude virtual bands for complex datasets ?
Antonio Valentino antonio.valentino at tiscali.it
Fri Jul 1 11:09:42 PDT 2016
Hi Bugbuster,
Il 01/07/2016 08:52, Bugbuster ha scritto:
> Hi Antonio,
> I did try the test suite you provided. I tried to convert all VRT images to
> GTiff with the simple command :
> None of them gave any results.
please ensure to have gdal_PIXFUN.so in the GDAL_DRIVER_PATH:
env GDAL_DRIVER_PATH=../../.. gdal_translate -of GTiff pixfun_cmul_c.vrt
pixfun_cmul_c.vrt.tif
> In each function, I added a debug message when testing the number of source
> rasters :
> I always get :
> If you have any ideas, I would be very grateful to you :-)
> Thanks
> Philippe
regards
Antonio Valentino
