[gdal-dev] Amplitude virtual bands for complex datasets ?
Antonio Valentino antonio.valentino at tiscali.it
Mon Jul 4 10:52:40 PDT 2016
Hi Julien,
Il 04/07/2016 14:30, Julien Michel ha scritto:
> Hi,
> Started the work here :
> https://github.com/OSGeo/gdal/compare/trunk...jmichel-otb:enhance-complex-datasets
> For now, recognizes the following syntax :
> gdal_translate -srcwin 1000 1000 1000 1000
> DERIVED_SUBDATASET:COMPLEX_AMPLITUDE:s1a-s6-slc-vv-20150619t195043-20150619t195101-006447-00887d-001.tiff
> ~/tmp/test.tif
> I need to see about exposing those derived datasets properly.
> Antonio, I copied one of your pixel function for fast prototyping, I
> hope you do not mind. Of course upon completion of this work we should
absolutely, I'm happy if it helps
> merge properly all your pixel functions with proper
> credits/copyright/licence. Thing is I did not know where to put them
> within gdal.
cheers
Antonio Valentino
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160704/1ab2a62c/attachment.sig>
