[gdal-dev] File Geodatabase raster driver
jramm jamessramm at gmail.com
Thu Jul 7 05:53:04 PDT 2016
Based on Even's work on FGDB vector, I have begun looking at raster data,
here: https://github.com/JamesRamm/fgdb_raster_spec
So far everything I've found is pretty much based on the output of v the
dump_gdb script. I have two troubling areas currently blocking progress
1. I can locate pixel data blocks but cannot decipher how to read them, even
when the contents are known.
2. It is unclear how more than one raster is handled. It appears to be based
solely on the names of files but any patterns/groupings are not obvious
Does anyone have any more experience with this or any tips on how to
proceed?
View this message in context: http://osgeo-org.1560.x6.nabble.com/File-Geodatabase-raster-driver-tp5275154.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
