[gdal-dev] Failure Building GEOS on Windows w/Mingw
William Kelly Magee William.Kelly.Magee at leidos.com
Thu Jul 7 09:31:30 PDT 2016
Hello
I am using GDAL-1.11.1 and have built it to use GEOS successfully on
Linux.  I need to build the same on Windows and am using Mingw32.  No
problem with GDAL but am running into an issue building GEOS on Windows
using Mingw.  I have searched the GEOS site but cannot find a solution.
The GEOS build failure is as follows;
    Making all in locate
    make[4]: Entering directory
    `/cygdrive/c/build/geos/geos-3.5.0/src/algorithm/locate'
    .deps/IndexedPointInAreaLocator.Plo:1: *** multiple target
    patterns.  Stop.
    make[4]: Leaving directory
    Makefile:556: recipe for target `all-recursive' failed
    make[3]: *** [all-recursive] Error 1
    make[3]: Leaving directory
    `/cygdrive/c/build/geos/geos-3.5.0/src/algorithm'
    Makefile:595: recipe for target `all-recursive' failed
    make[2]: *** [all-recursive] Error 1
    make[2]: Leaving directory `/cygdrive/c/build/geos/geos-3.5.0/src'
    Makefile:469: recipe for target `all-recursive' failed
    make[1]: *** [all-recursive] Error 1
    make[1]: Leaving directory `/cygdrive/c/build/geos/geos-3.5.0'
    Makefile:416: recipe for target `all' failed
    make: *** [all] Error 2
I have tried both mingw32-make and (cygwin's) make, and still cannot get
a clean build.
The arguments I am specifying to configure are;
    sh configure --build=mingw32 --enable-static=no -enable-shared=yes
    --disable-inline
Any suggestions (aside from not using Windows) are greatly appreciated.
- Kelly
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160707/d1567b6a/attachment-0001.html>
