[gdal-dev] import gml with curves
Even Rouault even.rouault at spatialys.com
Fri Jul 8 14:20:21 PDT 2016
Piotr,
According to http://www.datypic.com/sc/niem21/e-gml32_Curve.html, "The curve
segments are connected to one another, with the end point of each segment
except the last being the start point of the next segment in the segment
list", which is not the case here. Hence the "Non contiguous curves" error
message. So I believe your GML geometry is invalid.
Even
> Hello,
> Is there any way to import properly to Postgis gml which contain curves
> with more than one segment ?
> Below I attach a part of gml with exemplary object.
> <gml:featureMember>
> <bt:Object>
>      <bt:ID>10000</bt:ID>
> <bt:geometry>
> <gml:Curve gml:id="ID_786" srsDimension="2" srsName="EPSG:2180">
> <gml:segments>
> <gml:LineStringSegment>
> <gml:posList>485840.70 318178.50 485819.70 318182.37 </gml:posList>
> </gml:LineStringSegment>
> <gml:posList>485825.11 318176.40 485826.88 318186.02 </gml:posList>
> </gml:segments>
>           </gml:Curve>
> </bt:geometry>
>   </bt:Object>
>   </gml:featureMember>
> And here is how I try to import gml:
> SET PGCLIENTENCODING=UTF8
> SET GML_EXPOSE_GML_ID=YES
> SET GML_ATTRIBUTES_TO_OGR_FIELDS=YES
> SET GML_FETCH_ALL_GEOMETRIES= YES
> ogr2ogr -f "PostgreSQL" PG:"host=localhost user=*** dbname=test
> password=*** port=5432" d:\test.xml -forceNullable -splitlistfields -nlt
> GEOMETRY
> And I've got errors:
> ERROR 1: Non contiguous curves
> ERROR 1: Curve: Got NULL geometry as Member instead of segments.
> I there any option or trick to import such object? Curves with one
> segment are imported without any problem.
> Regards,
> Piotr
http://www.spatialys.com
