[gdal-dev] Error in GDALWarp to NWT_GRD
jramm jamessramm at gmail.com
Wed Jul 13 06:40:49 PDT 2016
I have a strange error when reprojecting a dataset to NWT_GRD format.
e.g.
gdalwarp -of NWT_GRD -ot Float32 -t_srs EPSG:4326 test.tif test.grd
very quickly returns
Stepping through, I've traced this to a call to `GetLockedBlockRef` in
IRasterIO (rasterio.cpp) which is called when GDALWarp attempts to write the
first warped 'block' to the GRD dataset.
Somehow, a flag - `bJustInitialize` gets set to false, causing
GetLockedBlockRef to attemp a read operation before writing the block. As no
data has yet been written to the dataset, this read operation fails.
(Specifically, line 316 of grddataset.cpp in frmts/northwood)
Im struggling to find the cause of this. I am wondering whether I have
missed some implementation detail in the Create method of the NWT_GRD
driver?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-in-GDALWarp-to-NWT-GRD-tp5276136.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
