[gdal-dev] SPOT-7 and Worldview 3
Even Rouault even.rouault at spatialys.com
Fri Jul 15 09:02:55 PDT 2016
Le vendredi 15 juillet 2016 17:29:19, Shawn Gong a écrit :
> Hi all,
> I have downloaded and built gdal 2.1.1
> Ran some tests on SPOT-7 and Worldview 3
> SPOT-7 tiled dimap: the DIM_SPOT7_*.xml file was loaded fine. But the
> georeferencing was wrong.  The xml seems to indicate ITRF2005 (epsg 4896)
> but it has no projection information in gdal.  The individual geotiffs
> didn't seem to agree with the xml either
I've done improvements in the DIMAP driver (for v2 products) in trunk recently
to support tiled datasets. You may want to check that.
> Worldview 3: the TIL file was loaded fine. UTM georeferencing looks good.
> Thanks,
> Shawn
http://www.spatialys.com
