[gdal-dev] Unable to read in GML file via OGRINFO / OGR2OGR (attempt 2)
Even Rouault even.rouault at spatialys.com
Mon Jul 18 07:27:07 PDT 2016
> I've tried adding -dim 2 to ogr2ogr, but that doesn't seem to work. Is
> there any way to force ogr to treat these objects as 2D? Forcing object
> type isn't possible, unfortunately, since the GML file contains mixed
> types (linestrings, polygons, even curved polygons).
No, there must be something in the GML that indicates that it is 3D, but some
inconsistency afterwards.
> I can provide a 200KB testfile if that helps.
That would be helpful to confirm.
> Regards,
> Jelmer Baas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
