[gdal-dev] How to add an external mask as internal mask to a GeoTIFF?
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Tue Jul 19 05:51:07 PDT 2016
Hi List,
I have a 4 Bands (RGB-IR) GeoTIFF for which I also have an external
mask.tif which has been created starting from a mask.shp shapefile using
this command:
*gdal_rasterize -ot Byte -l mask -CO "TILED=YES" -CO "NBITS=1" -CO
"PHOTOMETRIC=MINISBLACK" -CO "COMPRESS=DEFLATE" -a cat -burn 1 -ts 16384
16384 mask.shp mask.tif*
So that my mask.tif is 1 bit B/W GeoTIFF.
Now, I would like to add it as Internal Mask of the main GeoTIFF.
I have played a bit with GDAL translate and buildvrt and, due to
constraints on number of bands, I ended up with this commands:
*gdalbuildvrt -b 1 1.vrt origin.tif gdalbuildvrt -b 2 2.vrt
origin.tifgdalbuildvrt -b 3 3.vrt origin.tif *
*gdalbuildvrt -b 4 4.vrt origin.tif *
In order to separate the bands
Then:
*gdalbuildvrt -separate out.vrt 1.vrt 2.vrt 3.vrt 4.vrt mask.tif *
in order to re-aggregate them into a single raster, together with the mask.
And finally:
*gdal_translate -of GTIFF -CO "PHOTOMETRIC=RGB" -CO "ALPHA=NO" -CO
"TILED=YES" -CO "COMPRESS=DEFLATE" -b 1 -b 2 -b 3 -b 4 -mask 5 out.vrt
final.tif*
So that I copy the 4 bands from VRT and add the 5th band as mask.
I have 2 issues with that:
1) This solution is really not optimal. Wondering if there is a single
command to attach an external tif as a mask band of an existing raster
(provided it has same CRS, resolution, bbox, ecc)
2) What I get is that the mask has been set as an external file
final.tif.msk.
Is there any config option or opening option to open the final.tif in
update mode so that the band mask can be added as internal geotiff mask?
Please, let me know what do you think about it.
Cheers,
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160719/45108d3c/attachment.html>
