[gdal-dev] How to add an external mask as internal mask to a GeoTIFF?
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Tue Jul 19 06:27:05 PDT 2016
Hi Even,
thanks for the feedback.
I was using it as a -co "GDAL_TIFF_INTERNAL_MASK=YES" to the latest command
and I was getting
*Warning 6: driver GTiff does not support creation option
GDAL_TIFF_INTERNAL_MASK*
Appending the line you provided me to that command worked!
Thanks.
Daniele
On Tue, Jul 19, 2016 at 3:12 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi Daniele,
> > I have 2 issues with that:
> > 1) This solution is really not optimal. Wondering if there is a single
> > command to attach an external tif as a mask band of an existing raster
> > (provided it has same CRS, resolution, bbox, ecc)
> None that I can think of. Your workflow is probably close to optimum if you
> don't want to create the VRT at hand
> I think we would welcome a contribution of a Python script that would allow
> things like :
> - gdal_add_band.py -mask in.tif mask.tif out.vrt
> - gdal_add_band.py -alpha in.tif alpha.tif out.vrt
> - gdal_add_band.py in.tif extra_band.tif out.vrt
> > 2) What I get is that the mask has been set as an external file
> > final.tif.msk.
> > Is there any config option or opening option to open the final.tif in
> > update mode so that the band mask can be added as internal geotiff mask?
> Yes, "--config GDAL_TIFF_INTERNAL_MASK YES". See "Internal nodata masks"
> paragraph of http://gdal.org/frmt_gtiff.html
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160719/47395e24/attachment.html>
