[gdal-dev] Getting the following error while building GDAL 2.0.2 from source
sablok sablok at amazon.com
Wed Jul 20 10:56:39 PDT 2016
I am trying to build GDAL 2.0.2 from source and while building it I am
getting the following make error, I am not too sure why is this happening,
any help is appreciated -:
/home/sablok/workspace/sablok/BuildDev/env/GCC-4.9.x/runtime/bin/ld: error:
cannot find ./ogr/.libs/ogrgeometryfactory.o
cannot find ./ogr/.libs/ogrpoint.o
cannot find ./ogr/.libs/ogrcurve.o
cannot find ./ogr/.libs/ogrlinestring.o
cannot find ./ogr/.libs/ogrlinearring.o
cannot find ./ogr/.libs/ogrpolygon.o
cannot find ./ogr/.libs/ogrutils.o
cannot find ./ogr/.libs/ogrgeometry.o
cannot find ./ogr/.libs/ogrgeometrycollection.o
cannot find ./ogr/.libs/ogrmultipolygon.o
cannot find ./ogr/.libs/ogrsurface.o
cannot find ./ogr/.libs/ogrmultipoint.o
cannot find ./ogr/.libs/ogrmultilinestring.o
cannot find ./ogr/.libs/ogrcircularstring.o
cannot find ./ogr/.libs/ogrcompoundcurve.o
cannot find ./ogr/.libs/ogrcurvepolygon.o
cannot find ./ogr/.libs/ogrcurvecollection.o
cannot find ./ogr/.libs/ogrmulticurve.o
cannot find ./ogr/.libs/ogrmultisurface.o
cannot find ./ogr/.libs/ogr_api.o
cannot find ./ogr/.libs/ogrfeature.o
cannot find ./ogr/.libs/ogrfeaturedefn.o
cannot find ./ogr/.libs/ogrfeaturequery.o
cannot find ./ogr/.libs/ogrfeaturestyle.o
cannot find ./ogr/.libs/ogrfielddefn.o
cannot find ./ogr/.libs/ogrspatialreference.o
cannot find ./ogr/.libs/ogr_srsnode.o
cannot find ./ogr/.libs/ogr_srs_proj4.o
cannot find ./ogr/.libs/ogr_fromepsg.o
cannot find ./ogr/.libs/ogrct.o
cannot find ./ogr/.libs/ogr_opt.o
cannot find ./ogr/.libs/ogr_srs_esri.o
cannot find ./ogr/.libs/ogr_srs_pci.o
cannot find ./ogr/.libs/ogr_srs_usgs.o
cannot find ./ogr/.libs/ogr_srs_dict.o
cannot find ./ogr/.libs/ogr_srs_panorama.o
cannot find ./ogr/.libs/ogr_srs_ozi.o
cannot find ./ogr/.libs/ogr_srs_erm.o
cannot find ./ogr/.libs/swq.o
cannot find ./ogr/.libs/swq_expr_node.o
cannot find ./ogr/.libs/swq_parser.o
cannot find ./ogr/.libs/swq_select.o
cannot find ./ogr/.libs/swq_op_registrar.o
cannot find ./ogr/.libs/swq_op_general.o
cannot find ./ogr/.libs/ogr_srs_validate.o
cannot find ./ogr/.libs/ogr_srs_xml.o
cannot find ./ogr/.libs/ograssemblepolygon.o
cannot find ./ogr/.libs/ogr2gmlgeometry.o
cannot find ./ogr/.libs/gml2ogrgeometry.o
cannot find ./ogr/.libs/ogr_expat.o
cannot find ./ogr/.libs/ogrpgeogeometry.o
cannot find ./ogr/.libs/ogrgeomediageometry.o
cannot find ./ogr/.libs/ogr_geocoding.o
cannot find ./ogr/.libs/osr_cs_wkt.o
cannot find ./ogr/.libs/osr_cs_wkt_parser.o
cannot find ./ogr/.libs/ogrgeomfielddefn.o
cannot find ./ogr/.libs/ograpispy.o
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory
`/local/home/sablok/workspace/sablok/BuildDev/src/BuildPostGIS/configuration/gdal/gdal-2.0.2'
make: *** [check-lib] Error 2
View this message in context: http://osgeo-org.1560.x6.nabble.com/Getting-the-following-error-while-building-GDAL-2-0-2-from-source-tp5277422.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
