[gdal-dev] JP2 Segfault
Even Rouault even.rouault at spatialys.com
Thu Jul 21 11:51:58 PDT 2016
Salut Yves,
> Using  --config GDAL_SKIP ECW doesn't change anything.
The name of the driver in that instance is JP2ECW . ECW is for .ecw files
> I can't understand two things:
> * first: why libNCSEcw is used instead of openjpeg200 lib?
Answered above
> * second: what kind of problem could trigger this kind of segfault?
Probaby a bug in the SDK itself. Is it with the old 3.3 version ?
Even
http://www.spatialys.com
